Front door hinge orientation
JDNs78FJ40
Draper Utah
Can anyone tell from these pictures if the hinges that mount to body are in the correct position? I know there are a LH set and RH set. I know my body and paint guy removed and reinstalled them but not sure if the orientation is correct since I can never get the front doors aligned and there is a lot of resistance just before they latch. Trying to get ahead of this before I put the top on. The first 3 are passenger side and I removed the top hinge on the passenger side for a better view and what a PIA that was.
These pictures of my FST 43's hinges seem to suggest your left and right hand sides are mixed up. Fat side facing forward-
Yours look my 1970.
Drivers side pic.
Thanks. Now I just need to figure out why I'm getting so much resistance when I'm about 6 inches away from it latching. It's enough resistance I'm afraid it will bend the door or crack the paint.
It sounds like you have new weather stripping on your doors. Is it OEM or aftermarket? If new, are you sure of the position it is on the doors? Have you tried to close the doors with all the bolts loose?
Yes, new WS from CityRacer all around and I made sure its positioned correctly. Yes, I don't really tighten the bolts down very hard after I get it to close. I can tell most of the resistance is on the bottom hinge. I've never loosened all the bolts that are hard to get to in the tub. Maybe I need to loosen all of those and see it that helps. I just wanted to make sure the hinges weren't in the wrong spot and it doesn't appear that are.
Had the same issue when I tried to save by using CR weatherstrip on my '72. After nearly bending everything to make them work and a ton of adjustments, I threw the CR weatherstrip away, bought new OEM and fitted it. First time out it was near perfect
I hope I don't have to go that direction. Getting the WS on was a major PIA so I can't imagine what it would take to remove it.. I couldn't get the 3M glue to work no matter what I did so I used something much stronger.
A little dish soap on the weatherstrip helps it slide into place vs binding up when it's new. I used OEM, and it was still quite snug when new, and OEM is a bit "softer" than the variant from Racer. The Racer flavor also needs the specific 3M glue (Super Black vs Black? or vice versa...I never remember.)
You can get a bit of an idea of the "springyness" I had with OEM around the 9:50 mark:
Door Install
