I decided to do my 120K oils by myself today and it was all success with rear dif, transfer, engine oil even loosened kdds valves and lubed them too however really hit the wall with front diff. The moment I loosened the fill plug I heard a whiff of a sound and as soon as I removed it oil started to come out from the fill hole...?? Car was on front jacks may be 1ft clearance from tires to ground but still oil should not come out from the fill plug right? I could not loosen drain plug at all after multiple attempt with wd40, pb blaster and ended up stripping it... I could not fill any more oil into the fill as it was still at the opening level already.. I put the fill plug back and going to drive on it tomorrow. What should I do? How the hell dealler overfilled it ? supposedly dealer changed it at 30,60,90K.. Today diff was cold and I am thinking driving it and then try to chisel the plug. would it be ok to use butane torch to heat it up? I was a bit concerned with all the oil around making fire.
