front diff question
northumberland, PA
hopefully someone can help me out here, i picked up a set of non locked axles out of a 94, im planning on using the front third in my minitruck housing, i was always under the assumption that the front diff was like a v6 rear 8", just high pinion, etc...i was kind of surprised when i pulled it out that its a 2 pin carrier like a 4 cyl diff:doh:....i have a lockright for a 4 pin v6 diff, and i need to know whether a 4 pin v6 carrier will work in the hp housing....anyone know?
i was also wondering if anyone happens to know if the hp front comes with a crush sleeve or a solid spacer?...i would assume a crush sleeve, so i was planning on ordering a solid spacer kit soon, while i have it apart to do a pinion seal i might as well put that in there too, but if it would happen to already have one that would be nice;p
yeah i forgot to mention i have a v6 rear on the way, that im planning on getting a full spool for, so ill have the carrier, and locker to fit it, im just glad it will work in the hp;p
thanks for the quick response...maybe ill sleep better tonight knowing that what i was hoping would work will actually work:D
Surprise! Yup, the non-locked front diff in the 80-series is only a 2-pinion carrier. But, fortunately the carriers can be interchanged with V6 (or turbo) diffs. Just keep in mind that the GEARS from a V6 diff won't interchange, you need reverse-cut gears in the HP.
Factory spacer on the pinion is a crush sleeve. Get the one from Marlin, it actually fits better than the kit from Trail Gear (BTDT).
gears high pinion/ etc
The carrier for a v6 diff will fit in the highpinion non locker diff. The solid spacers we sell fit well, not sure about others.
yeah i know the gears dont interchange, im using the factory gears that are in it, which are in good shape;p
why does the marlin spacer fit better?
