Front Diff lock light on??
Wilmington, NC
I was driving home today and my front diff light came on and I am not sure why? Turned off the rig and started it back up and it is still on?? THe front is not locked but the light is on. I did a search but did not find anything on this. Anybody ever had this happen.
Tim
I am the only one that has had this happen?
I was waiting for someone to chime in who could help. The way the system works, the only way I can think of for that to happen (without the front diff locked) is a short in the front locker wiring. There's a computer involved though, so don't take that as gospel. I'd start by looking at the plug and harness on the front diff.
-Spike
Diff lock indicator
Hi there. I have seen the same problem with the rear diff locker indicator on one of my trucks. Not sure what caused it to come on but I just engaged the center diff lock and cycled the rear locker in and out then turned the center diff lock off.
Problem has gone away for now.
Cheers
Both front and rear diffs have a position switch which is switched to ground to make the light come on, so you either have some water in a connector which is tracking to ground or a rub through on the wire to ground somewhere possibly. The ECU also grounds the wire intermittently, when the diff lock is selected when doing over 5mph or without the CDL selected, this is when the diff light will flash.
(This is of course only correct if the position switch in the actuator is actually not closed and turning the light on)
