Front Diff Cover Gasket Replace?
Lakewood, CO
My front diff gasket is leaking. Is removing the third member just as easy as removing the drive shaft, bolts, and separating the third member from the case? I don't think the pinion seal leaking. I also snapped one of the bolts trying to retorque the bolts (53 ft lbs was way too much!).
Any help is appreciated!
Not that easy... The drive axles are stuck into the third-member and prevent you from taking it out. You have to tear apart the whole axle.
If you are clever, you might be able to do as you said and then get some rtv in there to stop the leak for a while. You can't completely separate the third from the axle without pulling the axles, but maybe you can get enough room to get some sealant in the crack and stop the leak. But obviously the best way is to just tear the axle down and fix it with a new gasket. Do the axle seals and knuckle service while you're in there...
To get the diff out, need to take the spindles out to remove the axles, then the diff stuff. Don't need to remove the knuckles, but is a good opportunity, if they need to be resealed. This is why we never run the diff gasket, RTV is much more reliable.
The diff nuts torque to 20ft/lb.:doh:
That is all good information. Nothing is as easy as what it is in my head! Looks like I need to order some parts and do a bit more research. Thank you all for the information.
BTW 20ftlbs seems alot more reasonable on those tiny studs, I should have known better!
you my get away with simply tightening the fasteners at least for a while. seems like every time i do some rock crawling mine goes to dripping and then i find loose nuts..
Yeah I'm going to try and extract the broken bolt and retorque all the nuts to 20ft lbs and limp by for awhile. In the meantime I'll start gathering some parts and warming the wifey up to the idea of me being MIA in the garage for a weekend!
