Front control arm with Johnnie Joints
Sacramento Ca
Has anyone ever done this to the frame end if the front control arms? Seems like it would open up some flex, and Les binding on the bushings front AND rear of the arms. Thoughts?
There just isn't side to side flex, there is a lot of twisting, front to back going on. That why when one pulls a front bolt it give more freedom.
I like the idea but, how would you attach a Johnny joint to the radius arm?
Thinking of the twist lengthwise, from front to back. As the suspension cycles @GW Nugget , the bushings deflect as we've all seen in pictures. I'm just thinking along the lines of trying to eliminate some of that torsional flex on the top end.
@baldilocks a thought wound be to press out the old bushings and either make/buy a sleeve that would fit the o.d. of the jj to the I.d. of the radius arm. Yes, the jj's are wider, so a new mounts t would be needed, but this has me wondering.
It's the same principle of co.panies out there making shackle hangers for leaf springs that have a jj in them, help eliminate the torsional twist. I'm also watching folks redo shock mounts and keeping the mounting eyelet in the side to side position, instead of running it front to back, therefore helping that torsional twist issue. Won't net much, but it all helps.
Seems doable but I just installed new OEM bushings. :) Is this set up something you will pursue?
Sounds like you have a plan.
Does anyone knows the inside diameter of the control arms bushing area it's a dimension that I need for my next project...
How do you plan to reinforce the bracket on the frame to account for the lack of bushing?
That bushing is huge and rubber to allow compliance and absorb impacts.
I'd rather limit my articulation and not worry about fracturing the bracket and detaching the arm. One is MUCH easier to compensate for than the other.
