front brakes
I am going to attempt the front brakes on our '96 landcruiser this weekend, pads, rotors and a fluid flush. Any surprises or special tools needed? Also seems alot of guys are using the 100 series front pads. Anybody give me the pros and cons of the 100 pads over the 80's?? Thanks in advance
Frode
100 series pads have a larger brake surface area, leading to longer brake life, better stopping power.
I think you have to grind them to make them fit though
I just did my brakes last week and I would definitely use the 100 pads... I did and the result was amazing! If you are doing the rotors you mind as well repack the wheel bearings as well. Only special tool you will need is 54mm hub socket...
Good luck!
[edit] I didn't have to grind the 100 pads. They fitted perfectly!
what will I need to do the bearings? ANy suggestions on where to get the 54mm socket??
Frode
A 2 1/8" socket from Sears works. I use one from Napa, it may be a 2 1/4", it's a little big but still works great. I put 100 series pad and they fit just fine with no grinding.
I would just like to make the comment that when you add a larger surface area brake pad to a brake system that was specifically designed to work optimally with a smaller surface area, you do not know what you are getting. Comments like 'better braking' 'can't believe how much better the truck stopped' are legion with this mod on previous threads. I'd wager that merely putting new pads on would get these comments, and that these changes/feelings would occur with ANY fresh brake pads. Nobody has formally tested this, yet the comments persist.
All you can say with the 100 pads is this "My front pads have more surface area, and because of this I reduced the braking pressure my 80's system can put on the pad per square inch." Nothing more.
Sorry I'm such a wet blanket on this, but I think newbies should understand this mod is done to the brake system with zero actual measurement of its benefit. I could type here for 10 minutes solid on all the possible impacts (both positive AND negative) that this change could produce if the mod were tested in a proper way. Consider this. If this change made your brake pad replacement interval 10,000 miles longer, but lengthened your panic stopping distance by 18 feet - would you do it?
DougM (Mr. Safety to you)
As Ed McMann would say, "You are correct sir."
This was discussed years ago on the old 80 Series list. Same thing can be said about other parts of the brake system such as aftermarket rotors, stainless steel brake lines, etc. If the parts are old then replacing them with new will always make a difference regardless.
The first time I replaced rotors and pads I almost put myself through the windshield. It's amazing what proper heat dissapation can do.
Same thing with soft lines.
I strongly believe in OEM model specific parts.
This is good thinking. I never considered 100 series pads, but those slotted and/or cross-drilled rotors were starting to look good. My truck does stop well enough as it is, without my messing with the stock setup.
Any suggestions on the best grease to use to repack the bearings?
