Front Brakes
No, unless they show signs of damage.
I'm doing a total replament of brake pads and rotors on a 96 LX450. Do you recommend replacing the bearings?
Depends.
Are they loose?
Are they worn out?
Have they been run dry?
Do they have 450K miles on them?
Do you WANT to change them out?
I changed the bearings and everything on my truck at 196K when I bought it from the PO because it had very poor maintenance. I will not change the bearings again for another 150-200K unless something comes up because I may clean and repack multiple times during the life of these bearings. but I'm doing my OWN work. If you're paying someone else to do it, they may insist on new.
If bearings are properly lubricated and properly adjusted, they can last a VERY long time. The internal bearings on my differentials have 279K on them and have never been changed.
Depends.
Are they loose?
Are they worn out?
The truck has 236k on it. When I had brakes put on when I first purchased, they went ahead and inspected the bearings and said they were fine.
Then I would have them inspection and repack if they are ok.
Seals must be replaced.
I'd replace the bearings. Heck, while you are balls deep in the front axle you might as well do the whole knuckle rebuild.
On second thought - measure the front rotors before replacing, if they are in spec and not warped then just slide in new pads.
On first glance I agree, however, with having driven lots of high mileage old vehicles, driving out the races and installing new ones frequently, it wears the inside of the hub and as time goes along, each race fits a little looser than the last.
Eventually spinning a race. It happened to me on another brand and had to buy new hubs because I could never get wheel bearings to hold tension for more than 5000 miles.
Just food for thought.
