Front brakes, wheels, calipers
Houston
What started as a tire rotation advanced to replacing the front brake pads, then advanced to rebuilding the front calipers. I was replacing some autozone pads to Toyota 100 series pads and noticed the piston boots were ripped... (I ordered the seal kits a few months ago but never installed them.)
For those that missed the previous caliper rebuild threads, IF you have stuck pistons or are planning to rebuild the calipers leave the calipers mounted and remove the pads. After this just get inside and stomp on the brake pedal, I had 3 out of 4 pistons seized in each caliper and it took MANY stomps to free them. In the middle of the caliper rebuild I discovered that the calipers are not the 1994 OEM ones. The piston seals were made in the USA! With that said, the pistons were chrome plated steel, not sure if the OEM pistons are stainless? Due to some pitting on my pistons I either have to buy new pistons or new calipers later if they start leaking...
Question, my tires are rotated every 5k miles and the outer tread edge of the tires are wearing more than the inner tread edge. Eventually I will have to dismount the tires from the wheels and flip them to even out the wear. What causes this?
Outer edge wear can be caused by a few things. Too much toe in will wear the outer edges. As can worn steering components or loose wheel bearings. How's your front end alignment?
Alignment was good, or as good as the person who did the alignment... Wheel bearings are still tight and trunnion bearings, the tie rod ends are newish...
I will take it to a "better" shop and hope they do a better job, and also to measure the castor as I never checked or corrected it with the little 2" lift.
Just got back from a roadtrip after bleeding, the truck stops MUCH better with all the calipers working! It seems that I have been driving the last 75k miles with just the rear brakes and maybe 1 out of 4 pistons in each front caliper working properly... I guess that explains why my front pads were not worn much when I did my rear pads... (Note: a fluid change does nothing for the gunk that is stuck in the bottom of the calipers, the only true way to clean them out is a rebuild or replace.)
Does anyone make stainless pistons for these calipers? I have found a company that sleeves brake components with a stainless liner but have not found a source for Toyota OEM caliper pistons in SS.
During the last rebuild, a few of the piston's had some chrome plating flaking off and were pitted in a few spots. Recently noticed some wet looking seals on the front calipers indicating a very small leak.
So this called for another rebuild and figured I would install some custom stainless pistons in the calipers, well just finished the rears and the front are next. Ordered the pistons from user here back in 2013: TheBigBoy.
Older thread on how to rebuild/clean/reseal calipers: Brake Caliper Rebuild
