Front Brake Parts List Help
To follow on, if you decide to DIY (or provide parts to your indie)—look at the list @Ayune made, then call Cruiser Outfitters. You'll get all the shims at once, any individual seal, or you can buy a full rebuild kit. You don't even have to know a ton about what you need, they've done it a billion times and the kits don't "forget" anything. Hella easier than chasing down the individual parts somewhere.
X2 on using @cruiseroutfit for parts.
I just spoke to Cruiser Outfitters and they don't sell a front brake kit for the 100 series. Only wheel bearing kit. So, when the time comes, I'll order the Toyota parts separately and get the wheel bearing kit from CO.
We don’t stock a “kit” but we stock OE rotors, OE and Advics pads, etc. What are you after?
Would be really cool if you guys put together a 100 series front brake kit like you have for the 80 series. It would include the obvious rotors, pads, and hardware, but also the not so obvious items that you would recommend replacing while you're in there - oil seals, washers, various nuts, snap rings, grease, etc. I also totally understand that this might not make sense because there isn't a recommended "replace this while you're in there" list of parts?
I'm going to simply do a pad replacement this go around, but next time I'll DIY the front brakes and wheel bearings. Thanks for your reply!
Any difference in quality/performance OE vs Advics/TBK? I assume it’s negligible if y’all are selling it.
All great options, we consider it good, better, best. That said, the TBK line had been great for the $$
