Front Brake Part Revision
Central NJ
Have a '97 LC and broke the spring clip that holds the two pins in place that in turn hold the brake pads in the caliper. I was told the spring clip is NLA and they sent me a different part that is considered an upgrade. It is a long strip of spring like metal with a double hole at each end; the holes are the same distance apart as the pins and fit over the pins. I ordered two new pins too and they are longer than what was on the truck originally. However there is nothing to hold this strip of metal in place. So, has anyone else done this upgrade and if so, what am I missing? Alternatively, can I still get the original style spring clip? As always, thanks in advance for the help.
For things like this, your best bet is to contact a parts guru directly.
You can see what my brakes look like on this page:
The pins do go through the clips.
