Greetings all...I'm in the process of servicing the front axle after rebuilding it with all new parts about 3K miles ago. After I rebuilt it the first time, I ended up doing a lot of water crossings. I didn't think anything of it after that and the front end started to develope a noise which sounded like it was coming from the left front. I thought something came loose like a shock or something but couldn't find the culprit.
I didn't have lot of time so I took it to the local Toyota dealer (cringe) to have them look at it. The guy pulled the front diff plug and some water gushed out. Said it needed to be rebuilt. Taking it apart I discovered loose bolts on the DS steering knuckle drivers side and one of the studs and two nuts came out on the passenger side. Lesson learned!
I hate being a newb! Long story short I'm repacking/ replacing bearings now. They all seem ok..one of the trunion bearings seems to have a little more play in it than the others so I'm replacing that one. There are a few rust spots hear and there on the axles and spindles nothing major. A few minor looking wear spots on the DS wheel bearings where they ride on the spindle. All of the races look perfect. Is it necessary to replace the races if I'm putting in new bearings?
