- Joined
- Sep 9, 2003
- Threads
- 22
- Messages
- 46
First off i have a 71 and iam putting together a cut and turned front axle. i have some questions about torque which the FSM doesnt cover really.
The manual doesnt give a torque or anything for the bearing preload or the adjusting nut... i dont really know what to do, this is what the manual says. When i originally took it all apart the adjusting nut was only like hand loose, what should i do guys?
Install the claw washer and tighten the front wheel adjusting nut with front wheel adjusting nut wrench 09607-60010. Rotate the brake drum to -and- fro to seat the bearing into place. Next loosen the adjusting nut 1/8 to 1/16 of a turn, and check the brake drum rotation. If the brake drum rotates properly, install the lock washer and tighter the lock nut securlely with the front wheel adjusting wrench 09607-60010.
