Front Axle Questions.....????
Arkansas
OK.... I am 10,000 miles since my full front axle service. I put in the heavy duty Marlin inner axle seals and everything else was OEM from Dan. As part of my regular service, the other day I put some Moly in the knuckles and then checked my diff fluid. The original amber color of the new diff fluid I put in with the service is now green which means I have moly grease in my diff.
I don't have any diff fluid coming out of my wiper seals.
I want to know if this is normal? Does the knuckle grease routinely push through the inner seal without the diff fluid coming into the knuckle? And how often does everyone change the diff fluid?
Any ideas or comments?
Thanks!!!
What you maybe seeing is the residue left over and being washed out from the old stuff as its in all the nooks and cranies of the diff housing ,and 3rd member .
I wouldnt worry too much just drain and fill and check it again down the road .
Thanks!!!
bump for help
After I completed my front axle service I found drips of gray diff fluid. It was coming out of the breather hose. After reading up, I determined that the front differential was building up a vacuum and sucked the moly grease from the knuckles into the diff. I removed the factory breather hose and routed new fuel line up to the battery compartment and attached a cheap, see-through fuel filter at the end. I drained and refilled the front diff (all gray and soupy). Then I pumped a tube of moly grease (1/2 tube per side) into the fill port near the ABS sensors. No problems have come up since (about 8 months).
Reroute your front diff breather hose and see what happens.
Riley
Riley
Riley,
I appreciate the help. That sounds like my problem. I will check and reroute as suggested. I have been wanting to do the diff breather mod anyway and just never got around to it. Guess I'll do the rear after I finish the front diff.
Thanks again. Gotta love MUD!!!
Update! I just did the diff breather mod on my front axle because of the problems discussed above. When I pulled my stock diff breather off and checked to see if it might be the problem I found that it was completely clogged. I'm sure that is the reason it is sucking the moly grease into the diff from the knuckles as Riley suggested.
Here are some pics of the new breather. I did the front only but plan on doing the rear diff soon.
And a couple more...... Everybody loves pics!
It may not be a problem, but I decided to route the new breather hose with fuel filter installed to the battery compartment. It seems to be the best sealed location in the engine bay. Where you have yours (driver's side near brake MS), it may see road debris and water.
It probably will not be an issue, just a suggestion that I gleaned from other posters.
Riley
Another observation... I did not have any type of box/canister at the end of the factory breather hose. It was just a length of fuel line with the little flapper valve stuck in the end bolted to the frame with the same looking arm/bracket (bolt hole and a guide notch).
That must be something they installed after 1994.
Glad you found the culprit (pretty sure that it is, at least it was for me).
Riley
RIley,
I didn't think it would make much difference on the position of the line since it has the filter on it but just to be safe, I put a longer line on the end of the filter and routed it to the battery box. I zip-tied the line to the charcoal canister lines and it makes everything look cleaner.
I think I have read on here where the plastic box on the end of the stock breather line came in on the 96 models.
Thanks for the help.
What is the plastic box for? Is it a filter? Can it be discarded if I go the fuel filter route? I also read that you can take the spring out of the flapper valve and use it that way? Is that correct?
I'm not sure what the plastic box is for. I have not torn into mine but after reading on here, it appears that it is hollow and has nothing in it. Everyone here that has gone the filter route appears to have discarded the box. There is NO filter with the stock set-up. I think the set-up I have done here, as others, is the best and most effective route. It's a cheap mod.
My breather was clogged at the axle nipple and in the line as well. I can now blow air (with the fill plug out) through from the end of the hose at the battery box, through the filter, to the differential.
what size hose did you use for the breather hose and "about" how much did you use?
thanks, looks like a nice easy upgrade
also what kind of fuel filter did you use or will just about any fuel filter work?:)
The size is 1/4" and I started with 6' and had plenty left over. All you are trying to do with the filter is keep dirt / debris out of the diff, so the cheapest plug in filter will work. A small motorcycle or lawn mower fuel filter (1/4" size) is what I used. Found it in NAPA "one size fits all" area.
Here is an article about using the factory flapper valve IH8MUD.com - View Single Post - Diff breather extension.
:cheers: Riley
thanks for the info, yet another mod to add to the list, but that's a good thing
