front axle noise ... possible preload problem?
Cary, NC
I have searched high and low and couldnt find the answer to my exact problem so here it is:Last weekend I took the rotor off to put new wheel studs in and while doing this as most know I had to remove the two nuts and the adjusting nut(the one where you fold one tab backwards and one tab forwards to hold the two nuts in place) on the spindle(I believe this is what they thread onto)
Well to make a long story short I didnt use the fsm so I didnt realize that these nuts had to be torqued to spec and set preload on them....(I JUST found that out when I was reading through some threads when I searched for , birf noises, broken birf, axle replacement, grrr noise, etc)
Now I have a clicking/grrr noise when turning but not at all times that I just started to notice last night while on pavement(thinking it maybe a ujoint at the time).Then I went offroad ( had to help out a bud that for some reason LOVES mud and always seems to get stuck but he had beer so I didnt mind) when I put it in 4L the noise got louder. Then the 80 was parked for about an hour or so as he had somehow lost his keys. When I started it up to leave the trail the noise wasnt audible at all. Then I went to a friends house still thinking it was a ujoint and when I put it in reverse and had my wheels slightly turned it acted like it wanted to lock up (just the drivers side front wheel)
So pretty much my question is, by not setting preload could I have damaged my birf ? It was recently replaced(within 10k) so I am hoping this isn't the case. Or should I just tear my assembly back down , grease it back up, set the preload and hope that gets rid of the clicking/clacking/grr noise?
update just tried to put in reverse to back up and center in garage and front wheel locked up again ... what is going on ? any help would be MUCH appreciated as I am in charlotte and have to be back in boone for classes on tuesday(this is my dd)
I would definitely pull it apart to check everything out, re-grease it all and put it back together to FSM specs. Did you put the wheel studs in to the proper torque? Are your lug nuts all tight enough? It's pretty hard to bolt the brake caliper back on, are you sure it's tight enough and not intermittently dragging on the rotor? I'm thinking of things to check...
What do you mean by "locked up"? Is one wheel not moving, or do both front wheels not want to move? Could you explain this more? Hopefully someone else will chime in here.
If you didn't set the preload correctly, you likely wasted your wheel bearings on that side. Too loose= slop and wobble, too tight= crushed cage, overheated bearings and locking wheel....
Assuming the preload was set correctly on an 80. how much of a "clunk" is usually felt when checking the wheel for play?
So there should be no movement felt at all when rocking the tire/wheel when off the ground, or just a little bit is OK but not quite a clunk?
just took wheel off in the snow under my carport as I couldnt get it into the garage and found out that the top bolt on the caliper wasnt tight enough and had backed all the way out ... the caliper was dragging the wheel when in reverse ... my freind is heading to grab a bolt right now but we are still going to tear it down and torque it to spec ...
thanks for all the imput this is why IloveMUD...
This has been covered before in depth, but the way I do it is to tighten the inner nut while spinning the wheel to German torque. Then back it off and tighten gently until you get just a tiny bit of play. Then install lock washer and locknut, tighten to Wookie torque and then check. The tiny bit of play should be gone, but the wheel should turn freely. I have never used the fish scale method, but it seems to work fine for some folks. Kinda depends on temps and type of grease etc.
FWIW, I have used this method on hundreds of military trucks, both of my 80s, the 55, my T100, and the truck in my avatar with no problems ever. I did have to re tighten the T100 Passenger side after about 25k.....
