Front Axle maintenance
Sacramento, California
Website
www.instagram.com
This weekend and with the help of Eduardo and Amando, I did full maintenance to the fron axle on La Cabra.
After draining the oil from the front diff and removing the hubs, I removed the spindle bolts. As I the bottom bolts came out, dark thick oil started gushing out. The axle seals on both sides were gone.
It was a little over two years since I did my knuckle bearings and axle service. Back then, I got a kit from a friend who owns a Cruiser shop. The parts where not Toyota. Since the bearings in the kit where Koyo made in Japan, I thought the rest of the stuff was the same quality. It wasn't after they were in that I heard that those inner axle seals were not as good as the originals from Toyota.
When I decided to do this job I gave CDan a call. The man knows what he's doing. He knows all this part numbers by heart. Plus all you have to do is tell him what you want to do and he'll send you all the parts you need. Great service. A week after my call, I recieved a big heavy box full of little Toyota boxes. (I'm saving the empty Toyota boxes to use them next Xmas. I'll be giving gifts in Toyota boxes).
The good thing is that all the bearings looked good. Even though the birfields had been running in oil for who knows how long, they were in great shape. It was not hard to change seals that go behind the knuckle (half moon, felt plastic, metal). With the right tools, removing and installing bearing races is a breeze. (Knuckle and hub)
I installed new spindles, my old ones were in good shape and probably would have gone another 30k miles. Now I have a good set of spares. I also installed a set of rebuilt calipers from Toyota. They are a thing of beauty. Nice and shinny. Plus new brake lines and pads.
Since the front end was a part, I also took the opportunity to install a set of front spring urethane spacers from Slee. Now the front of La Cabra sits 1" taller than before. I did this, not to gain the additional height (although it's nice), but because I was having a little vibration coming from the front axle.
La Cabra has a 4" lift from Slee. To get rid of vibrations from the front axle I first tried caster plates with a front dual cardan drive shaft, that did not work. Then I tried Slee's front control arms dual cardan drive shaft, that did not work either. Then I tried my old stock drive shaft, plus Slee's control arms, that did the trick for 95% of the time. However, coming downhill and letting off the gas, produced a mild vibration. I've not driven the truck enough to rule vibrations out completely. But so far I've not had any vibrations. I'm very happy on this front.
Yesterday I took my truck to our local muffler shop. They replaced all the hangers on the exhaust system. La Cabra is riding very nicely and quietly too.
Next on the list of things to do is to install Simon's 80 Series LSPV relocation bracket. I think it will help the rear brakes do a better job.
I want to thank Dan for getting me everything I needed. And also thank Eduardo and Amando. Without them this would have been a long job on my garage. Plus it was raining pretty bad over the weekend. It's nice to work on a shop with a lift and all the tools you need.
The lesson of this story is that is better to get all my spares from CDan.
Regards
Alvaro
Great story Alvaro and thanks for sharing.
The inner axle tube seals made by Toyota have very subtle features that many people over-look when comparing them to after-market seals. The shape of the rubber sealing surface, the quality of the spring, and the rubber material.
People that save $1 or even $5 by buying non-Toyota seals are making a big mistake, particularly on one that is as hard to replace as those axle tube seals. Mine (OEM Toyota) have been in ~60k miles and about 4 years. It will be interesting to inspect them when they come out in a few weeks. As of now, no leaks on either side.
-B-
Alvaro,
This is my 3rd repack in 3 years, 30,000 miles--cruiser now has 160k. Evertime I sourced the parts from Dan. I also change the diff oil 2x per year--the front has been full of grease every time. I have changed the seals 3x. My diffs have extended breathers--have done many water crossings--not sure what the deal is.
Jason
Jason,
Check the surface of the axle where the seal rides. It could be that it's worn to the point that the seal is not able work properly.
I gently used 400 sand paper to smooth the surface to get a better seal.
Regards
Alvaro
Alvaro,
Nice - I'll second the kudo's for Dan but I think the other important lesson is to have friends like Eduardo and Amando! Nice to see Mudders hanging out.
DougM
-B-
The Toyota inner axle tube seals that I bought are not made by Toyota.
Well, don't keep us in suspense man! Who were the Toyota inner axle seals made by??
DougM
Yeah, tell us....
That is probable, but they are made to Toyota specs just like my Timken or your Koyo bearings are made to Toyota specs and sold under the Toyota brand.
-B-
good to know that oil will keep the Birfs going...
The question that strikes me is how long have those oil seals been gone and how many miles have they been run. AFAIK, once the oil seals go, so also goes the grease and that mix comes flowing out past the axle seals. I have no doubt that oil can lubricate your bearings for a while but that should be a fairly short while not worth more than 50 kms. or so before you're either shortening the life of your bearings or needing to add grease or oil.
Kalawang
Kalawang,
Let's just say that in two years I've replaced the front diff oil twice. Both times the oil was contaminated. I also added moly based grase to the knuckles on a regular basis (maybe 3 times per year).
This is not an acceptable way to maintain a cruiser. I'm the only one to blame for that. I had no idea that my knuckles where flooded with oil. I won't let this happen again.
Regards
Alvaro
if you check the grease level in the knuckle with a dipstick you should be able to see that the grease is liquidish, no?
Eric,
I did see that on my periodic maintenance. I added moly grease to keep the birfs lubricated. Now I know better.
Regards
Alvaro
