Front Axle Job = Alignment Change?
Hey Guys,
I resealed my front axle a couple months ago, and replaced the trunion bearings but not the wheel bearings. Now, my alignment is slightly off of what it used to be. Not crazy off, but different. Everything went back together fine when I did the job, and after a little bit of driving I went back in and re-checked and set the preload at 28-30 lbs. Is it normal for this job to result in needing an alignment?
Thanks
Russ
What part of the alignment is off? Camber, caster, toe? Steering wheel pointed the wrong way?
Unless you spun the tie rod ends around to change the length of the TR, I don't see how anything could change.
The steering wheel is now turned slightly to the left (counterclockwise) while driving straight (about 10 degrees off), and in looking at the wheels while the vehicle is parked straight forward, the wheels appear turned out a bit away from each other. So it looks like it's going down the road a little bit pigeon toed, not a lot but I think it's different than before the work I did. And I did not remove the tie rods.
Not really possible for you to change the alignment. The only way the front end can be adjusted is through shortenting/lengthening the steering links or with offset trunion bearings in some cases.
That is a pretty simple adjustment, should be checked, set, relatively often. Alignment Setting Toe
Thinking out loud here (Kevin can confirm/deny my idea) - but if your trunions were trashed I suppose maybe that could be a partial reason for it.
Is the steering itself still neutral & the sterring wheel position the only change, or does it drift a bit as well, like the toe-in on the tire changed too?
I've seen that happen, on an old Jeep Wagoneer. Everything was so trashed that it was pulling everything out of alignment. Then after replacing everything, it was so bad, we could hardly even drive it. The bearing were literally gone, and it was riding on the center solid part of what was left of the bearing!!
Anyway, yeah, it's possible. A few mm here and there could affect a few things.
I would say the steering feels close to dead neutral, though sometimes I have to put a very little counterclockwise force to maintain a straight line while driving. It's the fact that the wheels aren't showing me the same view when I stand at the center line and the wheels are straight forward which makes me think the toe in is off. The DS wheel is dead straight and the PS is slightly more open - I can see more of the knuckle, rotor, etc., when I'm standing right in the center line of the rig.
And it's a good thing this Kevin/Tools guy doesn't live close to me. I'd be stopping his place all the time to offer beer and gratitude, and ask for help. Genius Level Wrencher, seriously. I'm confident most professional mechanics don't have his level of expertise and skills.
When the LAST alignment was done, did the trunnions and wheel bearings get redone and adjusted properly prior to alignment? Unlikely if it was before you owned it.
The last alignment was done while I was the owner, but before I had ever opened up the front wheel bearings. Thanks, guys.
Then yes, your alignment would change. The GOOD mechanics will not do an alignment unless the wheel bearings and all steering parts have been confirmed or rebuolt prior to the alignment.
The steering wheel turned could simply be the drag link adjustment that is easy to do and does not affect driveability. The wheels pointing away from each other is toe-out and can be adjusted as described above or taken to an alignment shop for adjustment. They SHOULD verify that the entire assembly is in acceptable condition prior to alignment. Including tie-rod ends.
