Front Axle Identification
Inland Empire, Southern California
My 1970 FJ40 has front disc brakes. Trying to determine if the axle came from a later FJ40 or aftermarket brakes installed on the stock axle. Are there any tell tale signs or marks?
the housing could be older with newer components
if it has the large bolt pattern parts are 79+
small bolt pattern 78-
bolt pattern would be the 4 bolts holding the arm to the knuckle
pics would also help.
This is a large steering arm stud measurements if that helps you identify. 1979+ Mini truck fj40 and fj60
