lol I just got finished doing a full brake job on my 97 LC about an hour ago. You will need latex + mechanics gloves, snap ring expanders, torque wrench (one needs to be able to go as low as 48 IN. lbs.), Multi-purpose grease, new wheel seals (2), 2 new lock washers (recommended), a large breaker bar, a bronze hammer and punch (for cone washers on flange), and a good socket set. You also need one of those GIANT sockets and a 1/2" adapter to go with it. I made this list assuming you would repack the bearings since your seals are leaking. Allow alot of time for this project, if you've never worked w/ the fronts before, i'd allow 5hrs. or so to complete the job well.
Since you havent done this before I'll get you started. First, of course, remove the wheel with the car jacked up safely. Next, remove the entire caliper (a few big bolts on the back bracing it to the car not the 4 bolts on the caliper itsself. Hang the caliper up or put is so that it doesnt hang by the brakeline. Next, taking a hammer and flat head screwdriver, pop off the round black cap in the middle of the flange, remove the snap ring on the axle shaft behind it. Next, loosen the six bolts on the flange, not the studs your tires are on but the six smaller bolts, loosen them so that there is only a little play between the nut, the washer, and the cone washers. Now, using your bronze hammer and punch, hit the bolts right down the middle until the crush washers all come out. then remove the flange. Behind it you will see a lock washer behind a large lock nut, bend the metal back on the lock washer so it isn't over the lock nut. Next, use that giant socket mentioned earlier to undo the lock nut, then pull out the washer, then use the socket again for another large nut, then remove the thrust washer. Now you can remove the hub and rotor together as one piece, remove the bearings clean everything off, regrease it and put it back on.
It will be very messy, have a large empty garbage can and a ton of rags/paper towels, make sure you clean your bearings really well before repacking them, even though it may take a while, you'll be better off if you get everything really really clean.
