Front Axle / Birfield question
My wifes 1993 has had the front birfields clicking for sometime now and i figured it would go in and replace them. There is some birfield soup indicating that the axle seals need to be replaced as well.
My question is, do I really need to replace/upgrade the axles? Or can I just keep the stock ones? Mileage is 222K. We dont do any major offroading in it.
Thanks for any advice.
John
if the axle shaft is not grooved badly at the seal mating surface R n R and keep running those axles. No problem.
Even if the seal surface is mucked up you can over/underdrive the seal to find a new seal surface to ride on. WitsEnd products even sells an offset seal driver.
as far as birfs, id try filling up the grease level in knuckle to see if clicking goes away. IF not then options are to switch sides or procure new birfs. I like the trail tamer variety for blend of quality and value.
I haven't opened it up yet. Was just getting parts list identified when I came to the axle question. Will start this Friday. The overdrive seal is appealing.
I just finished my own front end rebuild and we used the Witts End seal driver with the Nitro rebuild kit. My axle shaft had some noticeable grooves so we erred on the side of caution and drove the seal past the groove. I was instructed to check the interior of the CVs for noticeable wear, grooves or slop. Mine looked okay so we reassembled as original. I did not have clicking prior to my rebuild, but my seals were completely blown on both sides. Hardly any grease left when we disassembled.
