Front AC Hot, Rear Cold
Tennessee
AC has been working pretty well. Didn’t drive the truck for a week and came back and the front AC is not blowing cold. Rear is blowing cold. The actuator works and allows the swap from heat to cold up front. The previous owner had a new expansion valve put in and it ran well up until now. I have attached a picture, the hard line from the compressor is ice cold and once it gets to the weird bend by the firewall the portion that goes downward is cold but the top facing portion that goes up and above the block to the other side of the engine is not cold. What could this mean? Block in line or something else?
Have you checked how much refrigerant is in the system? I’m highly unqualified on this one due to the fact it’s a JDM ( never had the pleasure ) some times a low charge will do odd stuff. Is there a separate evaporator core in the rear of the vehicle like on American vehicles with rear cooling? Lots of unknown variables due to being a JDM unit. Hopefully now people know it’s a JDM and it’s a 94 may help people give you accurate advice. If it came through my shop we would immediately check the status of the charge / get it to the correct charge and monitor gauge pressures while the system was operating then start trying to figure out from there. Good luck buddy.
