OK.. I can't for the life of me get the 3rd housing out of the axle assembly. I've removed all of the nuts and washers (some studs came along as well), and locked the differential.
Now, this is a full axle assembly off of the LC, sitting on jack stands. I manually actuated the locker with a battery following the instructions found here because the FSM can't label like normal people can on pictures.
Did I run the locker too far? I've actually cycled it back and forth several times and it continues to work.
Am I missing something?
Is it the stupid stud that goes through the locker actuator that appears to be rust welded to the housing?
I get just about a 1/4" space between the 3rd member and the housing but it won't budge.
Oh, I've searched and nothing besides pull the axles out and lock the diff comes up.
