Fried gauges
I was trying to fix my fuel gauge problem. The problem was narrowed down to a bad gauge. I have a 1971 FJ40. The back of my gauge had two terminals. The new gauge I was installing had three terminals--an extra one in the middle--must have been a later model. I had it working until I thought that extra terminal might need a ground. I jumpered it to the sender ground and the needle fell to empty. Now my amp,oil press and temp gauge do not work. Did I run too much current across them and ruin them?
Perhaps you sent a positive (live) wire into a ground?
Did you try it all again (after replacing fuses), but this time without connecting the middle terminal?
The amp..is it a stereo amplifier? If so, replace the fuse (if any) on the back of it. It will be a blade type fuse.
How do you know the amp meter isn't working? Most of the time when you are driving it just sits in the middle and that is where it is supposed to be when the alternator is working and the battery is fully charged. If you want to test it, turn all the lights on with the engine off and it should deflect to the left.
It was working earlier in the day but now it is resting at the far left and wont move when I run accesories. I had another gauge for a diff. application that I hooked up and it responded like you said.
Thanks
