Fridge Nerds - help me answer a few basic questions :)
I was just getting my fridge ready for a trip this weekend and plugging it in and took a look at the XT 60 plug it uses for power. The two male pins are kind of spring loaded things and they were a little compressed now compared to how they probably were new. I took a scratch awl and opened them up a bit. Made the connection noticeably tighter.
Where did you get that flexible cable track thingy? I suspend my heavy charger cable from the alt charger to my EcoFlow battery with a bungee cord. Works but a bit lame.
Amazon. I need to look up what size it is. I purchased a few sizes for trial and error.
Not sure what thread to post this, but it is related to my EcoFlow fridge. I run the fridge from my EcoFlow delta 2 battery via the cigarette barrel plug to the X60 plug on the fridge. I also charge a small EcoFlow river battery the same way from the rear seat cigarette lighter plug.
Both chords seem to be getting hot. The one I use to charge the river is worse.
I have noticed at times I can hear barrel plugs sizzle when they’re not seated. I really hate those things. I wish these batteries would come with the marine style ones that lock in. I am a bit surprised that the X 60 plugs show signs of heat stress as they are supposed to be rated for something like 500 watts. They apparently use something cheaper in the cable that’s used with the barrel plugs is that’s typically just 100
in the short term. I’m replacing these cables but ultimately I need to find a better way the new Delta 3 max plus has a 30 amp DC output Anderson connectors. I think I’m gonna upgrade to that and use some kind of DC distribution box and avoid these barrel connectors altogether.
Poor connections are the issue. Just not enough contact between them so the current that does go through heats them up quickly. My Nat Luna cable was poorly assembled and got hot. I rebuilt it and now it works great.
I wish power packs came with a set of female adaptors that one could select from. For instance, aux port (cigarette), XT60, Anderson, etc. Kinda like the Apple Universal Power Kit (those these kits are the male side).
I wish they would just have a high amp output with Anderson plugs that you could wire to a distribution box of your choice. The Delta3Max Plus does this but it’s only 30 amps. Better would be to just include 3 or 4 Anderson plugs. It would be handy to have one output that was at higher voltage with an Anderson plug so you could charge any other kind of battery with an Anderson XT 60 cable at high wattage.
I was gonna say.. I've pulled something like 150A on an XT60 for a short period.. no way it should be failing at 9.
Amazon, about $14 a 1 meter R18 10x11 mm open type
Powerwerx offers that setup.
I believe the “60” in XT60 is 60 amps rating. I assume the XT is the shape of the plug XT30 is 30 amps and physically smaller and XT90 is the big one at 90 amps. It’s definitely a loose connection that is burning the plugs.
