Frame Rust Repair - LR3
Newmarket, Ontario, canada
Was cleaning up the frame with a needle scaler and hammer to do a coat of Corroseal and found a bad spot on the bottom rear frame. It was a 1/2 inch drain hole and looks like it was clogged up and rusted out around it.
Top, bottom and sides are good. What is the best way to patch this. I have a flux core inverter welder which I am quite competent with. I will rust convert and Fluid film the inside.
Should I cut out and butt weld a 3/16 patch or lap weld overtop?
Ant help appreciated
I would surmise you'd have to cut around and maybe put a proper plate in? I am not a welder in any means, just a WAG.
https://www.roverparts.com/ may have some help/insight. They also run a youtube channel.
