Frame Rivit Replacement
Discussion in '40- & 55-Series Tech' started by TN Green, Aug 27, 2006.
  1. TN Green
    TN Green
    2
    Aug 27, 2006
    I am giving some thought to pulling my frame completely apart, doing some rust repair and preventive maintainance but I am not sure on how to replace the frame rivits. Has anyone else taken their fram apart? Any suggestions on rivit replacement. I have read where some use grade 8 bolts. Any ideas on bolts?
    Thanks
  2. Cruiserdrew
    Cruiserdrew On the way there SILVER Star
    15,525
    4,499
    Mar 15, 2003
    Sacramento, CA
    The rivets are 10 mm I think for the smaller ones which is almost exactly 3/8 inch. I had to replace the rear frame motor mount and used 3/8 grade 8 fine thread bolts and red locktite in place of the original rivets. I did run a 3/8 drill through the hole first. I don't know about doing a whole frame like that though.
  3. Pete
    Pete
    390
    80
    May 19, 2004
    Midwestern Flatlands
    Green,
    Unless you've got a frame jig I think you'd be asking for trouble if you completely disassemble a frame. You would never get everything realigned exaclty as it's supposed to be unless you have a jig. To replace one particular cross member or motor mount or shock tower or something like that like Drew did shouldn't be a problem. I agree that grade 8 bolts would work. High strength bolts replaced rivets long ago in all strucural steel applications.
    Pete
  4. my64fj40
    my64fj40
    1,646
    2
    Aug 6, 2005
    Corpus Christi/Austin, Texas
    You should NOT need to remove all the rivets just for rust preventive stuff..
    Just paint the frame and be done with it, plus like Pete said you would have more problems after removed..
  5. armourguard
    armourguard
    72
    Jul 10, 2006
    Auckland, New Zealand
    My64fj40
    Did you mean " shouldn't " on last :confused:
  6. my64fj40
    my64fj40
    1,646
    2
    Aug 6, 2005
    Yup that's what I meant
    My bad
    I'll go fix it ;)
  7. Blue77FJ40
    Blue77FJ40 SILVER Star
    2,406
    174
    Nov 30, 2004
    MD
    Acid dip is a lot easier.
  8. TN Green
    TN Green
    2
    Aug 27, 2006
    I live in middle TN. Do you know of any place close to acid dip the frame?
  9. kulangot
    kulangot
    1,757
    135
    Apr 15, 2003
    Los Angeles California
    You know anyone that does this DC? Is that place still out in Upper Marlboro?
    I know of a place in Richmond but they did a 40 frame for a friend and it did not come out super clean.
    thanks
  10. majojo4
    majojo4 SILVER Star
    378
    34
    Nov 3, 2007
    Oregon
