For Sale Section
Official
Lorena, as she sits $2500
List:
Longfield birfs, 80 axles with a spare front housing. Aussies F&R
39.5 IROKS on Trail Ready alloy beadlocks
FOR front springs
3FE and drivetrain
heavy duty rear drive shaft.
If I can't sell her as-is, then I'd consdier parting out. But I'd rather say farewell to her on a trailer.
Oh yeah, my 10k trailer is for sale as well! $2400 gets it! and it's awesome.
Official
List:
FOR front springs
3FE and drivetrain
lol... post removed. saw end results in "what about bob"... little more barebones than I was going for, haha.
The ad that's going everywhere else...
Selling my 91 FJ80 Land Cruiser, or what's left of it, as well as my trailer. Going to try a new direction, but this needs to go first.
It's basically ready for tube or pull the axles and tires for a project.
Truck:
39.5 Iroks
Trail Ready Beadlocks
FJ80 axles w/ Aussie Locker in F&R
(the front is the hi pinion dif)
Frankies Offroad springs in front
3FE/A440
Fuel cell w external fuel pump
truck has been built to crawl, and crawl it has. I do believe it's made Los Primos on the the tinyest tires to ever make that obstacle!, 30's!
Eric Hagan- Los Primos - YouTube
Trailer:
used less than a year!
10k 16' (2' dove)
5200# axles
axle brake
heavy duty fold up ramps
collar tongue
heavy duty jack
rub rails
radial tires great shape
12k load distribution hitch
various trailer locks wil be included
Trailer is BEAST
$4400 for the package deal!
Trying to get to the SRRS this weekend... if you are serious, i might be able to transport it to the event for you to take... otherwise, I'm in Auburn, AL
ARB Bullbar-winch version for '84 and '85 4runners and trucks. Excellent shape, the holes for the front shackle bolts were moved to fit with an aftermarket front spring hanger but could easily be moved back to stock. $600 obo, located in Auburn, AL
I have all of the bolts and hardware
$500 firm
Few things that I have:
1 stick (22' 3") of 1.75" 0.120" wall DOM tubing
1 stick (16' 4") of 1.5" 0.120 wall DOM tubing
$240 for both or $140 for the 1.75" stick and $100 for the 1.5" stick, obo
A brand new, never used Warn Roller fairlead from an m8000 winch, $40
5" front Allpro leaf springs for '79 to '85 Toyota trucks and '84 to '85 4runners, these will work with stock spring hangers $125
9- 15x7 aluminum factory Toyota wheels (6x5.5)-came on late 1st gen 4runners, 2nd gen 4runners, and '91-'92 80's, 5 have no wheels - $150 for a set of 4, 4 with worn out 31x10.50 tires-$200
Factory rollbar for an '84 to '89 Toyota 4runner, perfect condition, $60
2 -11" travel Rancho shocks, post on top eyelet on bottom, nearly brand new-have maybe 3 offroad rides on them-I went to longer shocks, these will fit the stock front shock towers on '84 and '85 toyota trucks and 4runners and possibly the earlier solid axle trucks, but I'm not positive about that, part number rs5234, cost $110 new - take $60 for the pair
Forward shift toyota transfer case, $75
Toyota 22re-head, block, intake manifold, valve cover, timing cover and chain, no exhaust manifold, no starter, no alternator, no injectors, no distributor, $300 OBO, motor is in a 1987 4x4 truck and ready to be removed, it was running when parked but had a bottom end knock
Smittybilt tube sidesteps for 1984 to 1989 Toyota 4runners, $50 for the pair
P30 Chevy Class A Motorhome chassis tracbar-Blue Ox Part number TT2300, I never even installed it. So it is basically new in box. $300
Everything OBO, Located in Auburn, AL, pm or email at
dragr at charter dot net
More stuff:
Smittybilt tube sidesteps for 1st gen 4runner $60
Gray vinyl rear seat for 1st gen 4runner $100 firm
Huge auto transmission cooler with fan-that's a size 13 shoe in the pic $100 firm
Front shackles for solid axle toyota mini truck, 6.5" eye to eye, $40
Rear shackles for toyota mini truck, 6.5" eye to eye, $35
Trail Gear bumpstop extension -new $20
Trail gear bumpstops-new $20
Trail Gear weld on turn signal kit $25
Hi lift jack holder that fits stock 1st gen 4runner rollbar $15
3rd gen 4runner rear brake line relocation bracket from Sonoran Steel $15
Hurst shifter handle $10
Pics of everything here:
Stuff for sale pictures by dragr1 - Photobucket
$140 for the 1.75" stick and $90 for the 1.5" stick, obo
Forward shift toyota transfer case, $60
Updated prices, somebody make me an offer on these 9 15x7 alloys that I have before I just scrap them
1992 80 series - H42 manual conversion
I was planning on doing some work on this before listing it but I can't seem to find the time to do it and other projects are piling up fast so I am going to list it here pretty much as-is for a while. The stock bumper in the picture will be replaced by either a higher clearance plate or probably a tube bumper in the next couple of weeks.
Stats:
1992 FJ80 ~250K miles
OME COMP springs - 4" front, 3" rear
pro comp es9000 shocks
H42 4 spped manual conversion(write up in sig line)
custom full belly skid plate
5 - 37x12.5X16.5 goodyear military mts mounted on Trailworthy Fab double beadlocks + 3 more unmounted goodyears
Aussie lockers front and rear
ironman caster plates
custom extended sway bar mounts and rear bump stops.
diehard platinum marine battery
custom 2.5" high clearance exhaust with magnaflow cat and muffler
pioneer front door speakers
rear heater bypass
New oem water pump
spare rear axles
within past few years new oem radiator, oem reman starter, oem intake hoses, oem belts except green stripe replacement for air pump delete, extended oem brake lines and all oem brake soft lines, rear main seal, oil pan gasket, wheel bearings, longfield lifetime wiper seals, marlin inner axle seals, 555 brand Tre's.
not installed:
new fuel pump sock, sleeves for front and rear panhards and rear lower control arms.
$5500
As mentioned it will have a new bumper and if there is no interest as is I will probably throw on some sliders and maybe a rear bumper. I still have the stock rear bumper and third row seats in the garage.
Known issues:
cracked windshield
tires aren't balanced as much as I would like
paint - hood faded, fenders flares either need to be installed(have replacements from a 94 available) or holes need to be filled, some scratches and small dents
oh gawd. My dream DD right there!
swap in Lorena's axles and tires on her and you are just a toybox away from the baddest full bodied 80 ever.
With me driving it... it'd be the crushiest 80 ever! LOL.
Get me a job up in bham... and we got a deal!
Stats:
rear heater bypass
New oem water pump
spare rear axles
not installed:
$5500
Known issues:
cracked windshield
You take PayPal? lol I don't think I could hide that expenditure (or the vehicle for that matter) from the wife...
Stats:
rear heater bypass
New oem water pump
spare rear axles
not installed:
$5500
Known issues:
cracked windshield
Ahhhhhh...so frigging tempting....
Does anyone have a passenger side battery box for an 80?
posted with my thumbs.
I got both sides.... sitting in my garage... how's $500 sound? Fair?
Bilstiens and Poly 1" spring spacers for sale from my 96 80.
100$ for all 4 bilstiens and 50$ for te set of spacers
-Nick-
I'll entertain trades...lemmie know what cha got...
-Nick-
silver billies? 5100's?
I'd like them. Not sure what i got that you would want though.
