Follow up brake question
After talking to my mechanic, it appears both my booster and M/C are bad. 72 FJ40 with mini truck disc conversion by PO. A replacement M/C seems expensive from online sources, I don't mind if it will work with the conversion, but I hate to spend the money and not fix the hard pedal problem. The booster isn't available from online sources I checked, and again, I don't know with the conversion. Is there a specific year and model of commonly available Toyota M/C and booster that will bolt in? I'm too mechanically challenged and have no extra time with my business and house remodelling to play around and modify or pay a mechanic to do this, I would like to be able to buy and bolt in what will work. Is this possible? Thanks for your help, guys:confused:
I used a booster out of a '91 Cruiser wagon. Go to a pick-n-pull and look around( I paid $30 ). Other years/models of Toyota will also work. Sometimes there is a spacer between the booster and firewall, you may need it to correctly mount the 'new' booster with the proper spacing to your brake pedal push rod. Also, there may be a little plastic check valve in the vacuum line between the booster and the motor, get it as you will probably need it too. My '71' FJ40 had the check valve mounted directly on the old booster so I had to go back to the yard to get the check valve.
I used a master for a '89' Four runner since I was going to 4wheel disc at the same time. It has a 1" bore and was a direct bolt in for me since the Runner had front discs and the residual valve for the rear drum brakes was in the brake line and not in the M/C. You may need to order a M/C since I am assuming you still have all drum brakes and will need the residual valves that are built into the drum brake M/C. Don't get rebuilt!!! I made that mistake once. Never again!!! To check the fit of the M/C to the booster output rod I put a very tiny bit of grease (smaller then the head of a match) on the very end of the rod. Then I set the M/C on the booster, being very careful to keep it flat to the booster. If the grease transfers to the cup in the end of the M/C and sets flat on the booster you are good to go. If it doesn't, or it won't set flat(rocks) then adjust the rod in or out as needed until you get the the transfer of grease when you test fit it.
Good Luck!
Hi All:
A Toyota 4wd "mini-truck" brake booster and master cylinder should work for your rig; in my '74 I used a '89 V-6 booster and master cylinder.
Good luck!
Alan
Thanks, guys:cool:. Alan- did that M/C and booster bolt right up? -Tony
Sorry to flog a dead horse, but does anyone know if the 89 mini v6 booster and M/C will bolt up? If so, I can buy locally and get my cruiser back on the road. Help!
It should. Get the firewall spacer and the external check valve.
