Flyewheel bolts
i'm gonna say possably.
i've looked at a crank, and the flywheel bolt holes go thru the crank.
and you have a main bearing journal just on the inside.
if i had my bearing set at work i could look at them.
i know the trust bearing is NOT the last bearing.
hopefully someone knows for sure.
did you get the bolts from toyota?
ask them if they had a part# change on the bolts.
just remember to put some RTV on the threads so they dont leak oil.
jim
Where did you get the bolts? Is it possible they're the bolts for a 4-speed flywheel?
3-speed flywheels DO NOT use lockwashers, so that may be the source of the extra lentgh.
That said, as long as they thread all the way in and don't bottom out (I can't remember if they would or not...), I don't think they'd hurt anything.
Both F and 2F used the same flywheel bolts, IIRC. The F had some locking tabs, one for each pair of bolts, so you used three. The only flywheel I have removed was on a 2F and it had no washers or locktabs, but I'll bet the bolts you have are to allow for thet thickness of tab/washer.
2Bad, I've heard of red loctite instead of RTV and there have been a few threads lately about flywheel bolts coming loose. Will either the red loctite seal the oil out or the RTV kaap the bolts snug?
Thanks,
Ed
Lock plates are right next to the alignment tool
Thanks,
Ed
i used RTV,not much, just enought for a couple threads, the lock tabs will keep them from backing out.
i'm runnin a 2f 4spd flywheel.and using the lock tabs.
Thanks,
Ed
Thanks for clearing that up. I couldn't remember how it went. The 3-speed flywheels use the lock tabs; the 4-speed flywheels don't have any mechanical lock.
When I first took my clutch out, the PO had added some lockwashers and it caused an interference problem between the bolt heads and the clutch disk springs. They 'self-clearanced' and worked fine for many years. I didn't know until my sm420 swap.
I used Loctite "Thread Sealer" on mine. No problems.
IDave first told me about them, but where did you get yours? Are they still available at ToyoToto? I think that is the route I'll take, as I am just getting ready to put the flywheel back on.
my lock plates were on my 3spd flywheel,i reused them when i put a 4spd set up in.
DenverCruiser said:
I got them through a bolt company my company deals with. I am planning on using both the thread sealer at the beginning of the threads and a little blue loc-tite at then head of the bolt.
I would strongly suggest getting the correct proprietary bolts from Toyota. They are precision shanked specifically to fit in the flywheel holes. Also, note how the stock bolts have a reduced thickness head to clear the clutch dist.
A standard 12mm bolt will be wrong in this specialized application.
Absolutely! They are not too expensive since you only need 6. Considering their location it is what you need to do.;) The ones I got from Toyota are also
black (phosphate?) coated and may well be a different grade than the standard 8.8.
This is really not where you want to save any $.
Ed
DenverCruiser said:
Our engineer here has told me that these are much higher quality strengthened bolts than what Toyota would sell.
They are $9 bucks each at Toyota.
Do you want to tear it all apart or destroy a clutch disc for $54?
I'll send you my old ones free if you want. It is that important.
The heads are not only a shorter profile, but I think they are a larger head than a standard 12mm bolt.
I can take them to the PO right now and send them Priority Mail, probably less than $5.
Just offering.
Ed
Since SOR lists the flywheel lock plates as available, I would bet Toyota dealers can get them, too. Definitely a job you DON'T want to redo.
Just offering.
Ed
Thanks but I still have the originals which are in perfect shape. I will probably just end up using them again.
Good! BTW, I was not trying to be a smart a$$, just didn't think you ought to go down that road.
GL
Ed
Hey, Dave, I just figured out that there should be lockplates on my old flywheel:doh: If I don't maul them getting them off.
Ed..............gettin' smarter on MUD:idea:
Ed
Ed
Ed! You had an "ah-ha!" :D
Yeah, see the pics. I think when I installed this clutch ca. 60k ago that I forgot to use loctite. One of the rubber pucks was completely knocked out, one or two others had chunks taken off. One bolt was thoroughly trashed and a second had had the head polished.
When I went in a couple of weeks ago to make the repair I used red loctite on the bolts.
