Fluid Heat Riser Bolt Size
mikealeus said:
A fluid heat riser is a piece that attaches to the bottom of the intake manifold after the stock exhaust manifold is removed because of installing headers, typically. It is plumbed into the heater lines and routes engine coolant to the bottom of the intake, to try and make up for the exhaust manifold heat that is missing since the headers do not attach to the bottom of the intake and do not transfer heat to the intake manifold as the stock exhaust manifold did originally. In cooler climates it is said to aid in the drivability of the truck. I do not know how much of that I buy into however. I have ran headers on a stock carbureted F engine in some cold temperatures (- 25 or so Fahrenheit) for a few years, and then a Weber 38mm on that same engine with the headers, and I am now running a 2F, with headers and the Weber, and do not have any issues with how it runs/drives when it is cold outside, and have not ever used one.
I have also operated other Land Cruisers that had them installed and could not tell any difference in performance.
It was –10 Fahrenheit when these pictures were taken....it ran fine.
:beer:
Hey Poser
Thanks for the info about the heat riser. Was thinking of trying it, don't think I will now. I have a stock except for header on my F engine and it is a cold blooded beast and I am in a much warmer area than you(Calif). Thought carb rebuild would help but not much difference. What's your secret? Also, you must have one heck of a heater or grande juevos. Dang that looks cold.
I'd be curious too, I have a strong running '76 2F with a header. Runs great in any temp, but warm up time on cold days is very long. I had always assumed that a fluid heat riser would speed that up, no? Once it's warm it runs great, so if there's no real benefit, I guess I'll move the fluid heat riser farther down the list.
