Floppy Fender flares
FT Lewis WA
First off I want to thank all you members for helping me out. I now own my dream rig and have big dreams for it. I am no mechanic but you guys help me do the impossible. Yesterday I did the CDL switch and pin 7 mod. I would have never have been able to do that without your help.
Today I yanked my running boards off, mudflaps and trailer hitch. On my rear passenger side once removing the running board I noticed the fender flare was loose and floppy. I looked in the FSM but it really only tells how to remove it. The part on the door is really floppy but the piece on top of the fender well is loose as well. I think the piece on the door might be from a faulty screw. I just havent found an article yet on how to tighten them up.
I am sure some wise ass will tell me to yank them off and not worry about it. They still shine beautifully for now, so once beaten up I will do the rhino lining deal. I actually like the look.
How do I tighten them up? and keep them serviceable for now?
Pull the door panel or the rear quarter panel. You'll see how they bolt in, it's pretty obvious.
I'd tighten them up and keep them on there. I personally like the look, and like that there's that bit of plastic/fiberglass between me and whatever hard object might dent some sheet metal.
Another thing you can check for is the adhesive on the molding between the flares and the body. If this molding is not sticky anymore, you can use a 3M double sided "molding tape" found in most auto stores. It's about 1/4" wide so you can use it to re-stick the molding between the body and the flare to give the whole thing a little more stability. Be sure to read the 3M package for proper prep work that needs to be done.
I had loose flare section on same door that I tightened up recently. Referencing FSM and with door open you can see two bolts to remove to pull flare (forward bolt inside rubber extension on bottom of flare for bottom bolt - the rear bolt just holds rubber extension to flare). There's a stud on backside of flair that protrudes into matching hole and bushing in door. This bushing was loose or just worn out on mine. I didn't have the adhesive that alia176 was referring to. I wedged a small piece of cloth into bushing to make it a tighter fit and reattached flair with bolts. I was thinking about using RTV or silicone adhesive or I guess you might be able to order a new bushing from cdan, depending on the level of your expectations. Mine seems to be holding up for now. If I have to revisit it, I'll try the RTV and molding tape, 1st. Replace bushing as last resort. Who knows - it might not even be available.
I had some broken mounts leading to a floppy flare. The stock adhesive strip is also shot. Replacing the broken mount has helped a great deal. I need to do the adhesive route, but I don't want to go that far until I decide on either repainting or some other coating as the rock chips and gouges on them are pretty bad.
Fixing the broken mount solved 90% of my floppiness.
