Floor pan section
I looks like I only have to replace a small section of the floor on the drivers side of the 63 fj45swb.
The Problem is that the clutch mc was probally was leaking before it was parked and continued afterwards. It is hard to tell in the pic because of oil that was spilled but what I need is the section inside of the white line, the rest is very solid and not need of replacement. I do not have many resources here in NW MT. for these kind of parts. Does anyone know of a place I might find this section between here and Seattle ? I Will be heading there this next week.
Thanks Myrle
Myrle, here in Helena, there is a 63 40 series I could get it cut out for you and bring it to Missoula. is there a crossmember there?
3 pups, That would be great!!
Yes there is a crossmember right in the middle of the section that I need. It is right below where the jog is on the right side of section that I drew but not needed mine is solid. I will get some good measurements in the AM. I'm not rushed at this point just trying to get everything lined up.
I hope you are getting the rain over there that we are here,
Thanks, Myrle
Mallred:
I cant quite tell from the pic, but there seems to be some moisture on the top of the tranny hump and goes to the floor. In my 76 the drain tube from the "vent grill" infront of the window falls straight thru the dash and out a gromit near the top of the hump. You may want to check to see if the drain tube is ok or needs replaced, I just decided to weld a patch pannel on the hood and end the problem.
Just a thought, My floor looked like that too!
Peace
Neal
there was no cowl vent on a 63
Meryl I'll PM you my #
