MY 66FJ40 has a new 2f with H42 tranmission and 3speed transfer I wanted to keep the dash mounted F.D. Vacume and Tansfer high low shifter in its stock position . and of cource I will have to cut the tranney hump for the floor shift boot. shifter linkage has been lengiend to allow for the longer H42 about 4 3/8" I read someware about this on MUD but the thread did not go into much detail about how to fix this that there may be a clearance problem with floor clearing the high low/shift arm and transfercase has anybody done this modification is it more than a couple well placed Bashes with a 5 lbs. single jack.....I will know more Saterday when I take the running chassey over to body and test fit the body......... THANKS JC
IIRC, the Hi-Lo rod should only have to be lengthened 3.5", which is the difference in length of the 4 speed over the three speed.
The transmission itself is taller than the 3 speed, so trans tower clearance relative to the transmission tunnel cover is super tight. If your rear motor mount donuts are a little worn out, that will help.
Diagonal tub brace on the passenger side is super tight to the hi lo pivot arm. I have seen some dimpled [like mine] and some that cut the brace to clearance the arm. Personal preference: don't cut if you don't have to.
Mark Hy just the man I going to call ....if I did not git an answer ......I could be wrong 4 /3/8 " cut first but since It works I could have made it shorter this what I remember ? also I have new moter mounts as I said I will place the body on saterday with new body mounts and see what mods are nessary to git the body clearance with out making a mess out of it, cutting the diagonal brace will be a option, but prefere to dimple as you said.I just dont want to use a body lift or use a floor shifter I want to git all metal welding and ect. out the way and go to finial prep on body work what about spacing the transmission tunnel cover with thick also 1/4" or 3/8" rubber ? also I saw on your web site It looks like you have a 3speed boot on one of your Fjs and did it use a retainer ring ? and what size hole for it ? JC
No cutting ! only knocked in the (dimple ala 65swb45 ) diagonal brace not a real worrie started with 1/8" ended up with 3/8 " Thanks Mark ! Did not git a chance to work out the tranny cover yet....
THANKS again JC
