Float sticking
Flagstaff, AZ
I just rebuilt my stock carb (not a Jim C) on my '71 FJ40 and it was running great then died when we were making some minor adjustments on it. Fuel started pouring out of the carb. Prior to this, it appeared the float was properly set based on the fuel at the "dot" in the window. Took it apart to see if the float became disassembled or if there was some crud un the needle valve or jets, but didn't find anything.
Put it back together and it ran great for 3 days then today it did it again.
Any ideas?
Went out and drained the bowl (sorry if I am calling it the wrong words - newb car mechanic) and she fired right up.
I did put on a new mechanical fuel pump - could it potentially be too high pressure on the fuel pump?
AZkick-n40 said:
Dumb questions:
what is Sea Foam?
Where do I get it?
How do I run it thru?
It's a fuel additive, much like the BGK44 or whatever...I really like Seafoam better, cleans everything out. you can also add it to your oil and etc...
Checker/parts america any of those places usually carry it. You can run the full amount in your tank, or pour 1/3 of it in your carb...has some instructions...I'm sure someone here will pull up a link...i can't seem to find one right now.
SeaFoam
http://www.seafoamsales.com/motorTuneUpTechGas.htm
