...More like "maintain" ha! As they say "I'm finally getting around to making a build thread"
Purchased in 2022 for more than I'd like to mention with several mechanical, electronic, and aesthetic gremlins.
The very first (and most important) item on the list became apparent on the drive home from the used car lot. There was a sizeable crack in the top of the radiator, and it was oozing then dripping and eventually blasting hot coolant everywhere. After a $300 dollar bill, a six pack of Millers and a 3-hour course in DIY, Flo was right as rain. Included in the DIY service was a new Thermostat, upper and lower hoses, and coolant (duh).
I am Flo's 3rd owner (or 4th... it doesn't matter). She was sitting all dandy in the Bently Chevy used car lot, sporting the ORIGINAL factory tires... from 2009... you can't even tell what model they are - they're so old. Dry rotted ticking time bombs. Anyway, after a few laughs and $800, she got new boots today (11/19/2026).
Those boots are meant for walkin', know what I mean, Vern?
I like to wrench a bit, but time is fleeting and my 2.5 year old little girl takes up almost all of my free time these days. Maybe I'll get more time in a couple years.
To make this a less-unfortunate read for the fine folks here, I've compiled an ongoing everchanging list of what Flo needs to keep her safe, comfy and on the road. I'll try to keep it updated as often as humanly possible for me. Also, I will be taking Flo to a shop for several of these items, despite how minuscule they might be to you REAL salty wrenchers
1. Replace Brake Pads and Rotors (new sets sitting in trunk.. just waiting for the perfect time to pounce)
2. Brake Fluid Bleed and Fill (shop - don't judge)
3. Wheel Lug Studs (shop - again, don't judge)
4. Replace TPMS sensors all around (yeah screw that - Discount Tires quoted $300)
5. Transmission Fluid Drain and Refill (Toyota specific shop - just want it done RIGHT)
6. Add: Aux. Transmission Cooler (DIY, maybe)
7. Replace Suspension Components with OE (shop - unless I can get the time - I like doing this type of work!)
8. Control Arms, Bushings, Etc. (definitely shop)
9. Drain and Refill on Steering Rack/Pump (shop)
10. Lube them Drive Shafts (my favorite part)
11. Drain and Refill all Diff's (DIY, maybe)
12. Coolant Valley re-Seal (avoidable right now - just weeping - probably shop sooner than later)
13. Fan Bracket with Coolant Overflow Tank (DIY)
14. Water Pump (DIY)
15. Serpentine Belt and Applicable parts and pullies (DIY, maybe shop - maybe have done with WP)
16. Radio Screen is shattered (replace with Hamilton - Maybe DIY)
17. Spark Plugs and Coils (DIY)
18. Fix Entire A/C System both Front and Back (back hasn't worked since purchase - it's HOT in Alabama in the summer - SHOP)
As for the "build" part of this thread... the laundry list of getting it back to seaworthy condition is enough for me right now. Plus, this truck is perfect for me and my needs in its stock form. Once all these items are accomplished and no other gremlins surface (i.e. cam tower leaks, valve cover gasket leaks, timing chain cover leaks, etc. etc.) then maybe I'll begin posting about a build. Until then, I'll be making time (and money) to get these items done and will document the work as I go.
There's a lot of great information on this forum and I'm hoping to contribute something that's worthwhile.
Anyway... here's a pic for attention.
