Flatlander’s 1974 FJ40
Dropped my IPhone today and shattered the screen. Took the truck to the Apple Store and when I was leaving thought this pic looked cool.
It's a good measure replacing all fluids since you don't know what the PO did, money well spent.
Keep up the great work!
Went ahead and drained & filled transfer case. Material on the full plug looks suspicious. The trans case was a little low....I've got a small leak somewhere.
Speedy sleeve has been installed along with a new seal. Either my speedo needs the double seal or I need to do the tranny fill plug to trans fill plug jump mod, or both?
That is a beauty! Are you considering painting your roof white? It is one of the signatures of the 40...
Next on the list ;) Another PO "mod" :bang:
Going T O P L E S S very soon. Plan to have finished by the end of the summer.
Getting ready to address the surface rust in the back and drivers side floorboard. I do have 2 small holes in the floorboard that need welded/patched. Reading up on Ospho & Mastercoat. @ginmtb is it as simple as cleaning & prepping, picking a product to invert the surface rust, then rattle can with 309?
I keep her in the garage and frequently wash and wax.
I have three different products I use for different applications:
- Rust Doctor
- Master Coat
- POR15
Surface prep is the key in any application. I have to tell myself not to be lazy and do it the right way. I think Master Coat requires the least prep for a top coat/encapsulating rust treatment. It is thick and can fill pits and then you can sand to a pretty smooth finish and paint. POR15 I tend to use on the undercarriage where things will stay black and aren't subject to much UV. Rust Doctor is very liquid so I use that where I may need to swish it around or have a hard time getting to it with a brush.
