flat towing the 80
miami, fl
good morning everyone,
I'm interested in flat towing the 80 behind an rv.
for those of you that do this,
1- what towing equipment do you use? (blue ox, roadmaster, other), why did you choose this unit? pros and cons since you purchased
2- what supplemental braking system do you use? why did you choose this unit? likes and dislikes?
has anyone purchased a baseplate for the 100 series and adapted it to be able to use it on the 80?
any other information on flat towing would be appreciated>
thanks
Simply pitting ‘flat towing’ into search bar yeilded many pages of results to look through.
However a :cookie: for you. Listed here is one of the most common and thourough threads ....
Please make sure to remove your shafts before flat towing
Not sure why you would need to do that. Have towed my 100 series 6,000+ miles merely put Trans. in Park and T-Case in Neutral
A 100 series is not an 80 series.... It is my understanding that the transmission will not get sufficient lubrication if it is being flat towed causing it to overheat and seize. And also Mr T says so.
A 100 series is not an 80 series.... It is my understanding that the transfer case will not get sufficient lubrication if it is being flat towed causing it to overheat and seize. And also Mr T says so.
I agree Mr.T says no. but many have done it successfully with no issues. Before I towed mine I spoke with Christo Slee and he said he saw no issues. The main difference between the 2 T-Cases is that one has the viscous coupler, but both are the HF2AV which was used 93 forward. Slee - 80 Series Land Cruiser Newbie Guide The HF2A was used up to 93. Check out the next link posted earlier.
This has been covered extensively, I don't care what Cristo says. I know transmission shop owners that have seen issues on 80 series that arose from flat towing. I trust my friend and Mr T the most. Why risk it when it takes all of 30 minutes to pull the shafts?
I wonder why Mr. T keeps talking about the transmission but not the transfercase. I don't think I would tow any automatic with the transmission in neutral regardless of how slow or short distance.
I know which one is easier to replace if it went bad, but not sure which is cheaper as I haven't priced them.
My bad, I meant to say the transmission will not get sufficient lubrication. It is my understanding that even with the transmission in park that parts inside the transmission are still turning.
The tcase is downstream of the trans and the trans doesn’t move if the tcase is in neutral.
All four wheels are going to be rotating at the same speed so I can't see that the viscous coupler would be impacted by flat towing. Just make sure the tires are all the same size.
