Flame the newby
So I sold my mini with my tires on it since they wouldn't fit the 16" wheels I have anyway.
After doing a bit of research I found that 305/70R16 costs about $50 each more then if I got 315/75/R16 in the brand I like. For $200 cheaper I can get 35" instead of 33".
I realize I need a lift of some sort, but what about gears on this gutless wonder. Will it turn 35" in stock form.
With 35s you will need a lift and having driven a 92' 80 for 13 years there is no way I would do it with out going to 4.88s. I had the 4.88s with 33 MTRs and that was at the bottom of the tolerance envelope. Since your changing gears might as well add some lockers :)
Yep, kinda what I figured. My mini was geared a ratio lower for fun DD. I don't want a vehicle I hate to drive every day. I would never gear without some sort of locker. Thanks guys.
I'm running 33's with the 3FE and 4:88's. Better than stock, but I would hate having 35's with 4:88's. Go at least to a 5:13 if they have them, or a 5:29 if your ever thinking of going bigger than the 35's. I drove for 7000 miles on 31" tires and 4:88's and the beast drove much better than the stock geared rig did. My RPM's at 80 MPH were right around 3G's. Power band for the 3FE is in the 2600 to 3800 range. I think that 5:29s with the 35's would be fine.
Is your mileage with 33's and 4.88's better than stock gears with 33's? I have contemplated it some but am just thinking about it for now. And right now I cruise at around eighty mph at around 2250-2500. Would running it at 3000 be worse for the engine in the long run? I always assume that lower is better but as I learn more about my '92 I don't assume as much. : )>
Yep, sounds just like my mini. I went 5.29 with 33"s even though I could run 35"s and still be at or just shy of stock gearing. The 5.29 and 33"s really make the truck move in town and don't hurt the freeway RPMs much at all......not that a 90HP 3500lb truck on 33"s has much of a freeway speed anyway. LOL 70 MPH is pretty much all she's got.
BTW where do I get R&Ps for this thing. None of the places I got mini parts seem to list a diff for this thing.
... I think that 5:29s with the 35's would be fine.
I've read here somewhere that getting 5.29s in to the semi-float rear is next to impossible. has to do with the c-clips and the depth of the ring gear. The gear man that put mine in asked permission to grind down a tooth so he could get the clip in.
Going 5.29s on the full floater is not an issue.
the Semi Fload is easy to recognize. It has a removable read cover. so if you peak under the rear of the rig and see bolts around the diff cover you got a semi float which came on all the 91-92s.
an easy fix would be to find an axle from a 93-97 and swap it in and get the rear disc brakes as a benni.
Good to know. Do they not make a "c" eliminator like that have for the fords? I am obvioulsy out of my eliment. I have seen the tooth ground like you are saying in the past. Doesn't seem like a big deal. If I remember correctly it's only in contact in reverse...maybe? LOL
