Flame the newby
Boise, ID
Hi all. I just picked up a 80 and will be starting the minor mods pretty quick. I currently run an 88 Toy in the rocks and will be selling it. My first question is, is there anything I can rob off the mini before I part it out?
Second is, can I run 33" on the 80 with just manafre spacers for now, or do I need to go all out right out of the shoot. I don't want to give away my tires with my mini. Any advice would be great. I have to keep the LC reasonably streetable since I will use it for my business vehicle as well. :cheers:
Oh and third, the rig I bought has a simple brush guard on the front. Do I need to run OME heavys for just that, I don't want too harsh of a street ride.
Welcome! No change from stock suspension needed for 33s or for a simple "damage multiplier" type brush guard.
Welcome!
First question: What year?
Can't answer anything on the mini. Not even sure about sensors.
33s will be fine with stock lift.
Brush guard, as in a damage multiplier? They're not heavy, but get ready to get flamed!
-Eddie
LOL Well that's definetly all the guard would be good for.
Thanks for the news, that's what I thought but reading some sites made me wonder.
Being that mine is the less then powerfull 4.0, will gearing be an issue for mild trail use with only 33s? My 22re pickup is geared to the extreme. 5.29 diffs and dual cases making an overall ratio of about 110-1.
I just put some 33" BFG AT's on my stock suspended 92'. They fit well, I do have a little rub on the front pass bumper if I back out of the drive-way that has a slight bump to it and at full turn. I had the rig loaded down this weekend and nothing rubbed, even on my old dirt road to our cabin.
I've got 190,000 on stock suspension, except for the new Monroe shocks (which aren't worth the money imop).
I've geared to 4:88's and have noticed a slow down with the 33's. Still not bad with the 4:88's., a tune up, tightened kick-down cable, accel. cable, and adv. timing.I think that 32's and 4:88's are perfect (actually measured 31"es on 15x10"rim). You will notice a big change in performance with the stock 4:10's and 33's. You'll be shifting more manually since the older Tranny's don't like to down shift much on their own. Off-road you should be fine. On road you'll be wishing for lower gearing.
IMEOP I would think that the 3FE needs 4:88's with stock sized 31" tires. 5:13's with 33's, and some 5:29's for 35's.
Gas milleage has dropped to about 12 MPG from 14-15 MPG. That's just a one trip test, with full load, and A/C running on some very hot days.
x2...
Are the 33s on the mini 15" tires? If so then that could pose a problem if you have a '93 & up FZJ80 running 16" wheels. Please DON'T try to fit the 15" wheels on there.
Dump the damage multiplier when able...:D
I agree with the boys that say you shouldn't need a suspension kit to run 33's. We tested our Downey 2.5" suspension kit in really screwed-up, crossed-up terrain and never rubbed, even with obnoxious 10" wide rims, never rubbed in worse case. The reason I bring this up is because almost any brand suspension (except probably Man-a-fre spacers) do let the tires go up into full original compression.
if your mini has 15" wheels they likely won't fit on a 93-97 LC. The brake calipers are too big for most 15" wheels.
Thanks to all for the feedback.
I have the real iron pig, 1991. LOL
I have been told that the 15" wheels will fit on my little brakes in the 91.
My mini had a real damage extender, a full exo, for a while. I just cut it off a couple weeks ago. I don't intend to wheel this rig quite as hard.
Here's some pics of the mini, and the new grociery getting LC (at this point at least)
the 91-92 80's came with 15" wheels. But the wheels on the rig in the photo are 16" from a 93-97
Nice 80 ;)
Poor mini-truck looks like it had a bad case of "pigeon toeitis" there at one time :eek:
And yes, from what I read 15" wheels/rim should fit on '91-'92 FJ80s so you should be good to go.
You know, that may very well be. I pick the truck up this weekend, and hadn't checked the wheel size since I planned on swapping. I was kinda hoping they were 15" Since I'm not sure my soft 8s with rock rash all over them, will look right on the 80.
Nice 80 ;)
That was a dark day. LOL I broke a tierod (was stock) which in turn broke that axle which in turn broke the other axle. There were CV balls all over the place. LOL I had to piggie back on a trailer of a friend to get home. Now I have a custom built 3/4 heim tierod system. No problems since.
Man that thing looks nice! I have that exact same brush guard. :-(. Hopefully I can ditch it soon. I have a 1992 with the venerable 3FE. He he. Anyway, I'm running 33x12.5 BFG AT's on the stock 15x7 rims. Yours are, as Cruiser_Nut brought out, the 16" rims. Either way, 33's seem fine with a stock suspension. I don't even think I have fully flexed mine out yet, but so far no rubbing and I have done some stuff. Anyway, you will love it even with the 3FE, stock gearing, and 33's. It isn't that slow. : ).
Well, I guess I'll be running the black wheels then. I probably ought to at least pain the rusty rock rash before I mount them on the 80. Bummer.
Anybody want some 16" with little michelins? LOL
You could powdercoat the 15's, or even just spray paint them black. Alot of guys have done that and it looks sweet. And you could just keep the 16" rims for when you have to buy new tires.
True, true. The wheels I have are pretty hammered, but are true and straight. What is the width on the 16" wheels that are on my 80? I need a minumum of 8" to run the tires I like.
they are 8"
That works. These tires are about half done at this point so I'll be running the black wheels for a few thousand miles. Of course I suppose the LC will be allot harder on tires then my mini is.
