Fjz80 0-60
It was. The Chevy I-6 was common and easy to work on, so Toyota based their design on it.
:meh:
It was my understanding that Toyota actually bought the 3fe tooling design and support from GM and that many chevy parts will work on the motors.
The chevy comparison is driven more towards the F, 2F and 3FE motors which were all pushrod OHV style motors and nearly direct copies of the chevy staight 6. The old F motors were and are extremely reliable and do not have any head gasket issues or anything like that.
I've heard somewhere on Mud that only the US version of the 1FZ is plagued by HG issues because of the aluminum head, causing the head and block to expand and contract at different rates.
In other countries, the head is made of iron, so it and block expand/contract at the same rate.
So I've heard.
:meh:
I'm sorry, but the 4.5 Liter 1Fz-FE is NOT more reliable than either the Chevy 292 I-6 or the 230/250 I-6 made by Chevrolet. Or for that matter, the 300 i-6made by Ford. Or the 225 slant six made by Dodge. Or even the 258 I-6 made by jeep. NONE of the above motors had head gasket problems at all , ever, without being run completely without coolant. It is a good motor, but it's newer technology makes it less reliable than anything with a single barrel carb and pushrod valves. I've seen a ford 300 six run completely out of oil , seized, let sit, refilled with oil, restarted and driven for another 100k with no additional problems.
That being said, I love to listen to my 1FZ sewing machine in the driveway for long periods. Sounds like a swiss watch on steroids.
Rant over, return to what you were diong.
the 4.9L i6 ford was a great engine, but all of these are apple to oranges when looking at the head gasket.
the dual overhead cam can not be compared to a push rod engine. the only similarity is the number of cylinders.
i don't know of ANY aluminum head dual OHC engine that can withstand a serious overheat condition and live to tell the tale.
the warpage is fast and furious. the extra tension and forces exerted on the head with the over head cam design create a great environment for failures if you don't keep your coolant system healthy.
My only question, then, is why the hell didn't Mr. T install an accurate temperature gauge, stock???
Aluminum head, dual OHC engine was not cutting edge technology when the 1FZ came out.
