This is cool, Toyota brought back the 'tuna can' idea from the 80! Don't forget your roots!
Ha. Figures they replaced metal which is AWESOME with plastic which is NOT SO MUCH.
I believe the use of the plastic housing would reduce the CIA temperature. In fact, I've been looking for a (cheap & easy) way to insulate the metal housing on the 80 after touching it after a hot noon summer drive![]()
I am always amazed, and sometimes scared, at what my Scangauge tells me the intake air temp is- WAY higher than the ambient air temp and WAY higher than what Scangauge tells you they think you should see:
Flame awayFIAIntake-Air-Temperature
CIA
"Temperature of the air going into the engine. Attemperatures warming it up."
highway speeds, this will typically be a few degrees
higher than the outside air temperature. At idle or
low speed, it may be much higher in temperature
than the outside temperature due to the low air-flow
into the engine and the high under-hood
Here is the Data from today's testing.
I had to make a run to Lowe's and since I forgot my wallet it was a two trip deal and got plenty testing done. Each way was about a 20 minute drive with some highway along the way.
During the entire time the engine temp fluctuated between 185* and 187*. This included idling time as well. The ambient temp was around 67*.
During initial start up the truck's Intake air temp was 66*
First drive out to Lowe's with a winter coat wrapped around the filter canister the Intake Air temps was a stable 82*
Coming back from Lowe's to retrieve my wallet without the coat around the canister the intake air temp was 92*
Second drive out to Lowe's with the coat re-installed: the intake air temps returned to 82*
At this point when I returned home I did an idle test with the coat still installed but with the hood open and then closed. Since I expected the temp to rise I immediately opened the hood first.
Hood open: the intake air temps rose to 91*
Hood closed: the intake air temps remained at 91*
At this point if you intend to positively effect your air intake temps it would seem that insulating the canister is really the only way to do it. Maybe at some speed the louvers might be of some help but I couldn't reliably predict where they would have to go.
Anyone have some ideas of what to use as an insulator? Something in a sheet material with an adhesive backing would be ideal as I can CAD up a pattern and use the equipment I service to cut out the shapes needed to wrap the canister.
insulate the can and silicone intake hose... what ever happened to that Samco deal?
i think people said they dropped IAT 10+ degrees F with a snorkel
