FJCamo Intro - She's a beast
I would imagine that is a custom setup, so only the PO knows! Lots of guys on here use dual tanks, but the switch over/venting/return seems to be all over the board. If you can figure out which tank is currently in use I would stick with it until later down your list in case you run into water, filter, rust issues in the lesser used tank- one less thing to troubleshoot until later
So... do I need to manually switch tanks or do they feed off the same line? Still figuring out all the gauges and buttons (most of which don't work!). Thanks!
Follow the hoses to the switching valve and you should be able to tell pretty easy.
