FJ80 transfer case question
I just changed the transfer case oil today.
Can someone confirm that you DON'T need to remove the skid plate to remove the drain plug on a '92 FJ80? I saw pics when doing a search that you need to remove the skid plate but when I got under the transfer case, there was a drain plug on the bottom of the transfer case that didn't require removement of the skid plate.
I was only able to pump 1.25-1.5 qts of gear oil in there before oil started seeping out. I was on flat land while changing the oil.
Hope I did it correctly, The gear selector feels smoother while shifting from L-N-H
TIA
x3
You are all good. I just changed mine a couple weeks ago in my 92. I did the same process.
Same here.
Just did mine also.....I did remove the skid plate, mainly to clean. I had to remove the speedo cable also to get to the fill plug? Cleaned it off also....dirty
Whew! Thanks everyone! Wish Toyota made the 24mm drain & fill plugs deeper to prevent stripping. This goes for the differential plugs as well. Feels like they will eventually strip for being so thin.
You're OK.
You don't have to remove anything for a drain and refill.
Capacity is 1.4 qts.
Cool, read somewhere the transfer case took 2 qts so I got a little confused. Started to pump the oil in there faster but it kept leaking out so I gave up & plugged it up. Was left with about 0.5 qt, will save for next time. Thanks, now I feel much better knowing I did this correctly :D
Make sure you use 6 point sockets. I have a special 24mm one that I ground down the chamfer on the end. This gives complete engagement.
Yeah, wish they sold the sockets w/o the lead in chamfer...couldn't find any and don't have a grinder :frown:...will probably change the plugs out next time...they look like they're ready to round.
Had the same problem with my 12pt 24mm - oddly, my 15/16 sae fit tighter and I used that (it's a 6 pt)
