Post 27 second and third picture show a little tab sticking up to bolt the fender to it has a nut welded to the back.Hey what did you do to bolt your front fender back in on the bottom after you put that square tube in
Looks great! I did something similar, still have yet to do the passenger side because of the cats, not sure what I'm doing with that yet. I cut the rocker, capped with plate and attached a 2x6 to the frame. A lot of work but the result is well worth it IMO.
Looks very similar to what I did, but I unpicked the lower door jamb section (above your laser) at the pinch weld so I could weld the cut pillar to the RHS box section.
