Fj80 problems
United states
I have a 91 fj80 front axle broke replaced it took it for a drive noticed a little strain n vibration thinking driveshaft I remove it and tried to drive it again with only rear shaft on n it does move unless I put diff lock in low on t case any ideas?
You need to provide more info on what you replaced and a better description of the vibration. Removing a driveshaft requires the locking of the center diff. Your observation is perfectly normal.
That's normal. You need the center diff locked if you're only running one drive shaft. You can unplug something to keep the center locked but in high gear. Center diff button will get you there too.
These trucks are all wheel drive and the transfer case works like a rear end. If you jack up one side of a rear end the car won't move in less it has a locker and you lock it. Same with you transfer case if you remove one drive shaft it won't move in less you lock the Center lock.
The 91 / 92 have a center Diff lock switch on the dash you can use that to lock the center diff in high range so you can drive it around tell you figure out whats up with the front axle.
