FJ80 Overheating
Cottage Grove, OR
Hi. Over the past few months I've had to add coolant to my overflow about every couple of weeks. I've been meaning to have it checked out, but until last night it was running fine, with the gauge at bet 7 & 8 o'clock. Last night, I added some coolant at the gas station (a 50/50 mix) and just after getting back on the road the temp started to shoot up. 11 o'clock is red, but once it got to 10 o'clock I cranked up the heater until it backed down to just above 9. Good thing I had a short drive home.
I thought I had an electric fan, but after talking to the mechanic today, he said I do not. He said the radiator has poor flow except at high revs and will need to be replaced, along w/the lower and upper hoses. $914 parts & labor using a new aftermarket radiator. Toyota wants $800+ for theirs. The mechanic is well trusted, but he's not a Landcruiser expert. Any input would be much appreciated. :bang:
What year and how many miles on the truck?
If you are losing coolant at that rate something else is wrong.
Are there any leaks?
Look for a KOYO brand replacement I think in the $400 range and get the hoses from toyota
Also you will probably need to rebuild or replace the fan clutch
These are all things you can do yourself if you are inclined to save alot of money
Or you could bring the new rad to the mechanic and have them install it.
The coolant is going somewhere. If not on the ground, then through the engine, which could mean blown HG.
Does the exhaust smell sweet?
At a guess, stopping allowed heat soak to kick in.
You may not notice the sweet smell unless you get right by the exhaust while it's running. I'd also get one of the test kits that lets you see if you have combustion gasses in your coolant.
Is the truck smoking at all like heavy white smoke?
Like Ebag said the coolant is going somewhere it is not supposed to
HG are not usually a problem in a 3fe but you never know
Is there an oil cooler on a 3fe?
You could also have your oil tested for coolant
What about doing the bubble test with the coolant overflow container
With the truck warmed up, you might need another hand, rev the motor up to like 2500 or so
While the motor is reving remove the overflow cap but do not pull the little tube out of the coolant
And look to see if there are alot of bubbles coming up from the tube in the coolant
This can indicate a HG failure
If it's the head gasket, why does it get cooler at higher revs while sitting still then? Anyone know who sells Koyo radiator's in Oregon?
At least try the overflow bubble test it is easy and is a pretty good indicator of a HG issue
You might try PMing Ammo, he's fairly near to you (Eugene). Dunno how busy he is though.
You can also have your mechanic run a compression test or a leakdown test. You can do the leakdown test yourself if you have access to an air compressor (HF sells a kit)
How about starting with the very basic things first on a 20 year old truck.
1. Flush and refill cooling system.
2. Replace thermostat and gasket.
3. Replace fan clutch.
4. Replace radiator cap.
Make sure to use OEM parts.
If you are loosing coolant, check the lower radiator hose, upper and lower tank seams on the radiator itself, rear heater lines under the truck.
