What would you guys recommend? This would be going on a rig with 37s and FJ80 axles. I'm planning on running hydro assist and looking at the Redhead 80 box, or possibly doing a Redneck Ram with a Saginaw box. Which one would you choose, and why?
Of those two choices? The FJ80.
I HATE standard style Saginaw and usual hackery that goes with it. I have one out of four cruisers with this style... and it has a completely custom front crossmember to ensure strength in the area.
The other three are or will be Scout boxes. Hard to find now days though.
Another option not often discussed here is the f150/full sized bronco box from the late 70s. Same forward facing pitman arm, mounts outside the framerail and will turn the big tires.
I've heard many folks gripe about the Saginaw setup because of the hole needed in the front cross member. This was decades ago so there's no comparison for me with the 80 box. I haven't even looked into that yet. BUT!
I was in an accident many years ago in the Zebranator where a girl ran a stop sign and I T-boned her at 40 miles an hour. It was such a hard hit, it totaled the Cruiser. Bent the frame to the right by about a foot. (she was going from my left to my right. FAST.) The cross member didn't have ANY warping, buckling, or tears in it. It help up just as if there was no hole. So I'm a fan of the Sag box. It's strong and in my case durable.
I guess I should also ask, will this work if I am pushing my front axle forward 3-4 inches with an 80 box?
Are you planning on running the OEM 80 arms or some high steer setup? I ask only because some of the various forward facing high steer
Setups use a shorter acting arm on top of the knuckle which reduces the steering boxes’ power to turn the wheels-less leverage.
Shorter arms would help with clearance for moving the axle forward.
How much do you understand Ackerman angle? Do those arms allow you to maintain proper geometry for road manners? Just throwing questions out there for you to consider.
