fj80 grease fitting size
I was under the impression that Automotive zerks were pretty standard. Got a grease gun at Pep boys and `Viola!
I replaced one and it takes only a couple seconds to unscrew it from the shaft so you can match it up. OK to drive without it in place with just a piece of tape over the hole to keep dirt out. Or order it from Cdan and it will be the exact part and it's cheap to mail a tiny item like this.
DougM
The fitting on the driveshaft has a tapered pipe-thread, the fitting on the spider bearing is smooth and presses in. The fitting in the Napa spider bearing was smaller with a 45* angle, the original was longer with a 90* angle, so I swapped them. They came out fairly easily with a twist and pull, and pressed in easily. You can see the shiny Napa fitting on the cement between these bearings, the Napa bearing sets have the original Toyota fittings pressed in.
Thanks for helping everyone
Thanks scottm for the info and pictures. The fitting that I need to replace is the one on the spider bearing. It's damaged somehow.....:)
Whups - should have asked which zirk fitting. Brother Scott's got it handled I see....
DougM
Whups, I think the original fitting had the 45* angle, not 90* as I said. The pic shows it pretty well. You probably have to drop the driveshaft to press or tap the fitting into the spider.
