FJ80! Dual Battery Setup
Kennett Square, PA
Website
cruisin4parts.com
I got the makings all ready for a dual battery setup and I can't wait to get started.:clap:
I plan on running a normal battery in the engine compartment for all the stock loads then putting an aux battery right behind the second row seats which has a fusebox to handle all the off-engine loads and non-engine loads (Roof Lights, Computer, CB, Radio [, amp :hhmm:]) Much like pnwadventurer.
I went with:
* Hellroaring BIC-95150B with Remote Module (The one with 2 lugs)
* 200amp Circuit Breakers (2)
* Bluesea 12 ATO Style Fusebox with Ground
* Optima Blue Top Battery (I think D34)
* Some Huge Interstate Battery
* 60 ft. of 8 gauge wire
I plan on doing this sometime this weekend (after I get my u-joints replaced).
I did have a question.
Does anybody have diagrams of an FJ80 Cruiser? Like drawn from above the roof, pointing down, showing where all the things are in the engine, then one for all the stuff in the cab? This way I can figure out where I can put things.
Also, any tips you other dual battery guys have from hind sight?
seek (search) and you will find...
i had duel batters under the hood of my fj80 but it was a 96. maybe able to do the same w urs
That's an FZJ-80. There is room those engine bays for a second battery. In the FJ-80, the battery is in a different location and a second one is hard to fit in there.
Besides, having a battery in the passenger compartment will make wiring things in there a little easier.
The EWD for the '97 has something similar (see attached.) There are 2 of this view with locations of cabin bits and 1 from above the bonnet depicting locations in the engine bay. You would have to find the corresponding manual for your FJ80. Check Jon Held's web site... I believe he has some images there that might be what you are looking for.
-B-
hm... Put the battery there and then just send the power lines to the fusebox behind the seat, or somewhere in the cab. Hmm. That might work. Can you show me the brackets you made? I'm sure I can make them, I just need a good look at them. Either way, I can't freakin' wait for this setup!
I'll try and dig some up for you.
