Fj80 brakes
Have a 1994 fj 80 with brake light coming on ...pads are fine ...fluid level down but no visible leaks. I have refilled it twice but same thing happens.....can't see leaks.... Any ideas?
have someone pump the brakes while you are sitting still and check all 4 corners AND the LSPV.
Or go find some fesh fesh to roll around in and look for the wet spot...
Visibly losing fluid in reservoir but not seeing any leaks
I that's the case, then you need to inspect what was mentioned above and also the firewall where the brake booster mounts as well as the master cylinder mounting. Also check the inside of the firewall/footwell for signs of leaks.
The fluid is going somewhere and it should be easy to spot.
